wat?
https://linustechtips.com/topic/522289-voltage-calculator/#findComment-6935992
Current X Resistance = Voltage
Jk here's a PSU calculator I always use
http://outervision.com/power-supply-calculator
~~~SnapDragon~~~
| CPU: AMD Ryzen 9 9950X3D | CPU Cooler: Gigabyte Aorus Waterforce X II 360mm |RAM: 2x32GB G.Skill Trident Z5 Neo RGB 6000MHz | Mobo: Gigabyte X870E Aorus Xtreme X3D AI Top  | Storage: Samsung 9100 Pro 4TB + Samsung 990 Pro 4TB + Samsung 870 Evo 4TB + Samsung 870 Evo 2TB | Graphics Card: Gigabyte RTX 5090 Aorus Master 32G | Case: Lian Li Lancool 216 | PSU: Seasonic Vertex GX-1200 |
https://linustechtips.com/topic/522289-voltage-calculator/#findComment-6936002
Sry on my bad eng. I want to calculate how much powerwill my pc use.
Psu calculators can give a decent idea of how much power your system may need but they aren't always reliable. I'd suggest sticking to power draw benchmarks instead. The graphics card is a good place to base total system power draw on since that's usually the most power hungry.
It might help to list your specs.
https://linustechtips.com/topic/522289-voltage-calculator/#findComment-6936018
PSU calculators are random bullshit generators. Don't use them
https://linustechtips.com/topic/522289-voltage-calculator/#findComment-6936026
Now im confused shoud i use that or not  :(
Give us your specs
https://linustechtips.com/topic/522289-voltage-calculator/#findComment-6936027
CPU: X4 750K
Motherboard: A55M E33
Graphics: R9 380
Ram 8gb ddr3
500W is more than you will ever need with these specs
https://linustechtips.com/topic/522289-voltage-calculator/#findComment-6936055
This is my current supply RX420H-12 should i change it?
If you intend to power the specs you listed, yeah--probably.
If you would like some psu recommendations, it would help to link us to where you're shopping and tell us your budget.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/522289-voltage-calculator/#findComment-6936137
