Hi! Was just wondering what is the Best Cable Gateway Router Out there, Im not looking to add an addtional $8-10/month on leasing a router from my ISP
Thanks for the Help! Links can Help as well if you can :)
MOTHERBOARD: Gigabyte Z170X-Gaming 5 CPU: INTEL G4400 CASE: DIYPC-SOLO-T1-R
HDD: 160GB SEAGATE SSD: 128GB SAMSUNG PRO 850
 POWER SUPPLY: 550W ANTEC
https://linustechtips.com/topic/520342-best-cable-gateway-router/
SB6190 is the top dog.  32 channels down and 8 up.  Supposedly supports gigabit speeds even though no ISP uses DOCISIS 3 for gigabit.
Cox in my area only offers 24 channels down and 4 up, so I'm not fully utilizing my modems capabilities.
You don't need a modem that expensive though unless your internet plan is that good (mine is 300 down / 30 up).  SB6183 can handle up to 600Mbps.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Its best to buy a separate modem and router. Those gateway devices seem to suck. Your ISP will have a list of approved modems. Then just go get a decent wireless AC router.
Rogers in Toronto has just begun offering 1 gigabit down and 50 mb up over DOCSIS 3.1.
Which is a catch 22 because I don't think any DOCSIS 3.1 modems can be bought right now.  Might be wrong, but it's bleeding edge..
I see the Touchstone CM8200 was "released" mid-october, but nowhere to buy it.
Not up here. You can't buy your own modem. Rogers will not activate any modem not provided by them, so if they are offering the service (which they are) they have the hardware available.
