New case fans installation problem
yes you can
they are just hard to screw in the first time
get a better screw driver or push harder
yes you can
Its not that they won't go in, its just the screws aren't big enough.
Thanks for reading this! Shame that there's nothing here worthwhile for you to read... but you are still reading. Why?
yes you can
And the fans don't come with any
are you sure youre using the right screws??
50-Pieces-LOT-Black-M5-10mm-For-PC-Compu
Are you sure? Every fan comes with screws. Some have also rubber mounts, but pic I googled about box contents shows correct fan screws. You are supposed to put screw first through case and then to fan. If you are screwing it to rad, you need to use screws that come with rad.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Well, in that case you'll have to buy them separately. Personally I'm drowning in the bloody things, but I don't suppose that's much help...
To be fair though, I do recall that my AF140 (and for unrelated reasons I regret to this day having bought the thing) did in fact come with four fan screws, so I would assume yours were supposed to as well.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
