Cheers to all,
I have a big problem with my Sapphire HD 7990 card,i mean many problems and I don t know for sure if this card is about to die RMA frown.gif
-Furmark can 't see 2nd gpu on this card,but in gpu-z say: AMD Crossfire enabled (2GPU).Also i activated crossfire from catalyst control center.I check my Device Manager and seems to be fine. Im confused why are these errors??Who lying device manager or furmark?
-In GPU-z in IDDLE mode ,one gpu temp. is 28 degree,and second gpu is about 67 degree,and first gpu have 0.85 Volt VRM and second gpu have 1.200 v. This behavior of this card is normal?
My SO is win 8.1 pro,and I have latest driver from AMD site named Crimson 15.12.I try with different old driver 13.9.Same issue,no succes.I reaplies the thermal paste on this card with Arctic Silver 5,but temps are same,and same issue in furmark(2nd GPU is undetectable)...
Before I purchased this 7990 card, I have an gtx 690 card.But on gtx 690 card I have no issue on Furmark and GPU-Z.It was working flawless.With this hd 7990 I have only problems:(
This card is about to die (RMA),at least I want to know the truth??
Thank you all and I wait for ur answer,
post-299396-0-10599300-1451886133_thumb.
post-299396-0-07089000-1451886143_thumb.
post-299396-0-58787900-1451886147_thumb.
https://linustechtips.com/topic/520016-problem-with-hd-7990-card/
have you tried uninstalling drivers with DDu and reinstalling the latest version?
Just an FYI, Furmark is best used on setups without dual GPU graphics cards-the resulting heat caused by furmark can cause problems on dual GPU cards.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
God love me.I resolve the problem.I use DDU to uninstall driver,then I reinstall latest crimson 15.12 and now both temp on GPU are fine,max 23-27 degree in idle.The problem was in POWER PLAN.IT was set to performance that's why gpu nr.2 reach at 67 degree.I set on Balanced and now is fine.
But why Furmark don t detect gpu nr.2?Is still weird ......
