I wanted to know what ram speed is used for. Does it make games/programs load any faster? For example, how much difference are there between a DDR4 2133 mhz and a DDR4 3200 mhz?
It's helpful for RAM-intensive applications, which is not games or anything normal people do. Heavy video editing or 3D modeling or something like that might see a marginal improvement but overall RAM speed isn't really very important at all.
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907660
The difference will not be very noticeable, mhz are basically cycles per second, so the higher the cycles per second the faster RAM can be accessed by the CPU in order to complete tasks and access processes stored in memory. So 3200 would be ideal but once again, difference is minimal especially if you have 8+ GB
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907662
People have gained improvements using faster RAM in games, including Fallout 4 and GTA V. I mean like 10FPS gains.
Edited by Godlygamer23
Corrected typo.
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907674
Interesting. I haven't heard about it.
Edited quote to be in line with original post(edited)
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907682
Here you go: http://www.eurogamer.net/articles/digitalfoundry-2015-the-best-pc-hardware-for-fallout-4-4023
It's in the column to the left when you scroll down. Fallout 4 I think is the example.
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907689
Hmm. I am not entirely sure about other games though. Also to note too is motherboard compatibility since most motherboards on the market can't even handle RAM that's faster than what, 2800 MHz? Also I'm not super interested in fast RAM too since it can introduce stability issues even though there are motherboards that can handle RAM speeds in excess of 3866 MHz, and 2133 MHz RAM for DDR4 is the best since 1) it's very stable and reliable, 2) they're generally cheaper for various brands, and 3) it has the widest compatibility with motherboards.
Edited quote to be in line with original post(edited).
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907690
At least for gaming I haven't seen a noticeable difference between 1600MHz and 3200MHz DDR3 RAM in the same system.
I don't know how switching to DDR4 RAM might affect gaming. But since you'd need to change a lot to upgrade to DDR4 RAM
The new born system is expected to perform a little better then ;)
[never touch a running system]
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907855
I wonder if you're referencing the placebo effect, since you mentioned expectation and then a winky face.
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907938
No, sorry.
The thing is just if I'd wanted to upgrade to DDR4 RAM I'd need to change the cpu, the mainboard and the RAM.
So i5 4690K to i5 6600K, ASUS Z97-P to ASUS Z170-P, and Kingston HyperX Beast to Kingston HyperX Savage.
Even though these components are very similar they are over a year apart from each other. I really expect them to perform slightly better =)
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907955
No, sorry.
From a technical perspective, they do, but not sure if you would actually notice a difference depending on your use case scenario.
https://linustechtips.com/topic/520009-ram-speed/#findComment-6907986
I agree on that!
Personally I think I won't upgrade my system for the next 3 years.
When the new ZEN architecture from AMD or 8 core Intel processors are out and are really better for gaming I might be upgrading... ^^
If you want to discuss this further, you can PM me. I don't want to derail the OP's topic further.
https://linustechtips.com/topic/520009-ram-speed/#findComment-6908077
