Rosewill RCX-Z1 cpu cooler
aSpoink
Is the Rosewill RCX-Z1 a decent cpu cooler? My specs are in my sig. I cant find much online as far as reviews for it go, so I was hoping someone on here has had some experience with it. If its not a good cooler, please suggest me a cooler for $20CAD. Thanks in advance.
Link to cooler- https://ca.pcpartpicker.com/part/rosewill-cpu-cooler-rcxz1
I doubt it is any better than the stock cooler of your cpu so it's wasting your money for nothing. If you really need an aftermarket cooler, get the CM Hyper T4.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
Are you not satisfied with your current cooler?
I dont think that will fit in the Corsair Air 240.
No, I'm using the stock AMD cooler and I find my cpu gets too hot while gaming.
What are your load temps?
While playing games, temps can be between 80°c - 90°c.
That seems a bit high. how are your case fans laid out?
I have 2 intake fans in the front of my case, and 1 exhaust fan above my cpu.
Have you tried reseating the cooler?
Yes, and nothing has changed.
Huh, it might be due to lack of thermal paste.
Anyway, the RCX-Z1 isn't much better than the stock cooler.
A Hyper 101 would be better: http://ca.pcpartpicker.com/part/cooler-master-cpu-cooler-rrh10122fkra
