NAS and SAN, NOT for home users and small businesses...
Hmmm,
I see a lot of interest in this topic, because of the many responses. I consider that a good thing.
My reason for starting this thread is to encourage a synergy of hardware and software people to fix what is apparent (to me, and only me) in the very process of rebuilding a drive can cause another drive to fail, thus ending the rebuild process.
There are more than one 'bad' guy in this flawed process. It is NOT my opinion. it is a fact, based on the stories I have heard.
One of the ways to fix, is to avoid hard drives - use only SSD (or something yet to be invented). Problem? SSD don't have the capacity, as yet and are expensive. And the way life is, a new problem will surface. Technical progress tends to take care of problems. But if no one thinks there is a problem, no one will be working on the problem.
I am old enough to remember when the fastest storage device on a computer was a 'drum'. It rotation speed was about 11 milliseconds, and that meant its access time was 11 ms. Far faster than the hard drives of that day.
Now, I can have a faster drive in my pc, and much larger, too.
Raid was created to deal with slow and unreliable hard drives. Adding more options to the raid 'equation' did not fix the drives. But progress in the hard drive arena did. Raid has its uses, and also its failures. ZFS, as far as I can tell, demands more of the hard drive than it can actually provide. Recognition of that is in the resilver process. However, that process should (until a better solution comes along) be gentle in the rebuild process. After fixing one drive, it will have to fix another drive, and so on. Beating a drive to death in this process is foolish. So a better way is needed.
Best regards
On RAID cards and ZFS you can set the rebuild/resilver priority. ZFS has even better controls and limits on this process than hardware RAID does.
