Ram channel help?
Go to solution Solved by Mug,
It'll be referring to 4x16GB DIMMs.
Essentially, having a dual channel motherboard means that two of the memory sticks inserted will be paired for higher throughput.
By having four memory sticks in, your motherboard has two dual channel pairs. Memory cannot be mixed in a pair. Slot layout to ensure paired memory is shown in the manual
There are no performance or stability issues when using 4 DIMMS in your board at once (although there were at the start of DDR3).
Dual channel is when you use 2 pair of ram, or 4 dimms. 32 gig dimms do exist, but typically 16 gigabyte dimms are much easier to find. So to support 64 gigabytes, you use 4x16gb ram
Don't be fooled by the bottom line of my sig, that is just for my travels.
So you're telling me that Gaben is no God? Enough of your foolishness.
My hardware you ask? I'm using a Dell Inspiron 3217 Notebook... With an LG 25UM57.
https://linustechtips.com/topic/518710-ram-channel-help/#findComment-6892964
https://linustechtips.com/topic/518710-ram-channel-help/#findComment-6892971
Asrock Fm2a88x+btc says that it supports dual channel only but has 4 slots Why and it says it supports 64gb of ram in dual channel do 32 gig dimms exist? Can I use 4 dimms if so are there any performance of stability issues
Yes, you can use 4 dimms, but it will have no performance improvement over 2. Basically, if you have 4 dimms filled, the CPU will treat it like you only have two(if you have 4x4gb for 16gb of ram, the CPU will treat it like 2x8gb). You can run 4 dimms in dual channel config, the CPU just won't get the full bandwidth it would if it had quad channel. There is no advantage of going 4x4 versus 2x8, so unless you need 64gb ram go with 2x8 or 2x4.
Hope this helps!
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/518710-ram-channel-help/#findComment-6892975
this is the most accurate response. The other two are wrong.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/518710-ram-channel-help/#findComment-6892983
That
Not this:
Dual channel means that the 4 sticks are put into 2 channels. So you can have 16gb in 1 slot and 16 in the next and it will act like 32gb.
So u can run in dual channel while only having 2 dimms
CPU: R7 5800x -- Mobo: Gigabyte B550 Gaming X v2 -- RAM: 2x16GB Kingston Fury Renegade -- GPU: Asrock RX 6800 XT Phantom Gaming OC -- Case: Fractal Design North Walnut/Black Mesh -- Storage: 2TB 970 Evo Plus, 4TB NM790 -- PSU: BeQuiet Pure Power 11 Platinum 650w -- Displays: AOC AGON  AG352UCG, Dell Ultrasharp U2715H -- Cooling: Noctua NH-D14 -- Mouse: Corsair M65 -- Keyboard: Func KB 460 MX Blue -- Sound: Motu M2 -> THX 789 -> DT880 600Ω -- Mic: RØDE NT1-A
RIG 2: Intel i5-8400, 16 GB RAM, RTX 2070S
https://linustechtips.com/topic/518710-ram-channel-help/#findComment-6893014
