Hey there, Around April time I'm doing a planned upgrade on my pc, I'm switching out my motherboard so that I can switch to an I7 4790k, of which I plan to overclock, I will also be picking up either a second R9 290X or going up to a 390X, now for the I7 4790k, I would like to water cool it, now my question is, which is safer due to leaking? Should I go with a custom loop, or just an AIO? I've heard many stories of AiO's leaking, especially Corsairs, but then there is always the risk with custom watercooling loops as well, for the custom loop I would most likely use soft tubing when I first set it up, and later in the year switch to a PETG piping (just personal preference on aesthetics) If I went with a custom loop, I would also pick up the second 290X and cool them then, but with the AiO I'd end up picking up two Kraken G10's and putting AiO's on them, but honestly my question is, which is the safer to use?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/518283-aio-or-custom-loop/
i would go for a custom loop, it will look much nicer and you only have yourself to blame if it leaks :P
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888499
do a custom loop! (its a new experience, it performs well, itss fun, it allows you to tinker with your computer, it makes your computer more personal to you and you can do almost what you want with the asthetics of your loop)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888511
AN AiO is safer for leaks because if it leaks it's not your fault its the manufactuer. So AiO cooling is a lot safer than a custom loop. And you're on the right track with what you're doing. Starting with soft tubing is always a good idea for first timers. And then when you have experience with custom loops you can start doing hard line. But then again, it is pretty hard for leaks if you know what you're doing.
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888517
AiOs are far easier to use, and have a low likelihood of mistakes.
Would this be your first custom loop? It would be a fun experience, though expensive.
It totally depends on whether you are satisfied with your current performance. If you are, then liquid cooling would be a fun endeavor, for purely aesthetics.
You might have a tough time in that case though. The Core series is not meant for watercooling, though it is certainly doable.
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888518
Should I go for a seperate GPU and CPU loop, or double up on radiators (2x 240mm) and do the single loop
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888522
well your in control of a custom loop, and a aio only should last for 5 years were a custom loop you have to clean every year, but those parts like the rad, cpu block, etc should last forever.
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888532
Yeah I know the price is higher, but I'd be willing to pay for that, and I love the V21 so would like to try it, but if not I'd switch out to the of the Corsair Air series cases
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888533
single loop as then you only need 1 pump and its less maintenance and less to go wrong.
Rig Specs:
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888537
Okay
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888539
just do a single loop, becasue youll lose out on some cooling performance, and it costs more to do two loops.
https://linustechtips.com/topic/518283-aio-or-custom-loop/#findComment-6888543
