This is my current build plan http://pcpartpicker.com/p/mNkzt6 should I change anything and also I need to get a mouse. I already have a keyboard, the corsair k70 CherryMx blues with red LEDS.
Thanks!!!
https://linustechtips.com/topic/516918-my-first-custom-built-pc/
Give me a moment.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard  ($64.99 @ SuperBiiz)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($298.99 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($59.99 @ Micro Center)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  ($55.80 @ Amazon)
Total: $793.36
Generated by PCPartPicker 2015-12-30 17:31 EST-0500
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/516918-my-first-custom-built-pc/#findComment-6872438
Thanks!!!
1. You should not get a FX processor for gaming
2. Get a better GPU than a 750ti, something like a R9 380
Here, something like this:
Motherboard: Gigabyte GA-B85M-GAMING 3 Micro ATX LGA1150 Motherboard  ($57.75 @ OutletPC)
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card  ($223.98 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case  ($47.99 @ Micro Center)
Total: $765.19
Generated by PCPartPicker 2015-12-30 17:27 EST-0500
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/516918-my-first-custom-built-pc/#findComment-6872444
Total: $765.19
I want to play games like cs go so do I really need that upgrade or can I just do with a 750ti?
https://linustechtips.com/topic/516918-my-first-custom-built-pc/#findComment-6872503
If your only playing CS:GO then get a G3250 or 860K and a R7 360/750ti
https://linustechtips.com/topic/516918-my-first-custom-built-pc/#findComment-6872514
Here, this build can do much better in gaming.
Motherboard: Asus B85M-G R2.0 Micro ATX LGA1150 Motherboard  ($36.98 @ Newegg)
Memory: G.Skill AEGIS 8GB (1 x 8GB) DDR3-1600 Memory  ($33.99 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case  ($37.99 @ Micro Center)
Total: $767.53
Generated by PCPartPicker 2015-12-30 17:43 EST-0500
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/516918-my-first-custom-built-pc/#findComment-6872550
