Hey guys,
Got my new Samsung Pro 950 256GB SSD today (M.2)
It's all working fine the only thing is i can't get more speed the 830MB/s read and 800MB/s write. It should be 220MB/s read and 900MB/s write.
Any one know what I should do to max it out?
I7-4770K
Asus maximus VII hero
Corsair vengeance 2x4
BTW I used CDMark to test the speeds
Thx in advance
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/
Hey guys,
I7-4770K
Thx in advance
Its reading at 830/800 and you want it to read at 220/900??
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6872069
Use screens of the test?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6872077
M.2 port on Z97 can't go past ~800.
PCI-E M.2 Adapter  or similar
Never mind I'm stupid, I think possibly...
Checking benchmarks
I'm not I was right.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6872083
Screenshot?
Yes.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6872104
Hey guys,
I7-4770K
Thx in advance
The M.2 Port on Z97 is not capable of full speeds. That's why.
sex hahaha
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6872137
So basicaly I F'ed by choosing this SSD?
No, you can buy an adapter for it.
http://www.amazon.com/Addonics-ADM2PX4-Pcie-4-lane-Adapter/dp/B00KDM75XK
Little bit of research says this should be good.
sex hahaha
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6872165
So yh, I kinda already wanted to upgrade, what chipset/socket or w/e will support this by default without a bracket
Z170 or x99.
Yeah your motherboard is PCIe gen2 then...
OR it's Sata, not PCI-E...
sex hahaha
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6872375
Right, that's also an option... But I wouldn't expect an NVMe drive to work on that?
They do, they're just slow.
sex hahaha
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6872742
So, what should I do buy a random pretty expensive converter from some chinees company or upgrade to z170/x99. I just really want no bottlenecks. I'm looking for a Asus maximus VIII hero, will this handel my SSD?
Yes, any Z170 will.
I would personally just get the adapter.
sex hahaha
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6874386
It depends really, can you flip your old hardware and buy new hardware for less than the adapter?
Because I doubt your CPU is slow...
https://linustechtips.com/topic/516896-samsung-950-pro-256gb/#findComment-6874798
