Reference vs non-reference
Go to solution Solved by 007agentHP,
reference - nvidia/amd/intel developed cooling
non-reference - developed by 3rd party companies which are generally better in cooling and provide better overclocking performance.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
Reference < Every other thing ever
Best way to put it i guess.
CPU: Intel Xeon E3 1231 V3 3.4ghz CPU COOLER: Cryorig H7 w/ Red Corsair SP120mm  MOBO: MSI SLI Krait Edition Z170 MEMORY: G.Skill Ripjaws 8gb (2x4) Storage: Kingston V300 120gb, WD 1TB GPU: MSI R9 390X CASE: Phantom 410 (ew) PSU: Thermaltake Toughpower Modular 550w CASE FANS: 4 CORSAIR SP120mm MONITOR: LG 25UM67 KEYBOARD: Das4 Ultimate Cherry MX Blue MOUSE: Deathadder Chroma Left-Handed AUDIO: Sennheiser HD598 Black, Astro A40s
reference is the oem cooling solution that nvidia amd and Intel use for their processors
non reference is 3rd party development that usually a better asus evga sapphire gigabyte msi ect.
these videos might help
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
not necessarily reference is usually rear exhausted which can help in some small form factor cases it really just depends on what you need
Please don't spread this nonsense. Reference cooler is superior for SLI and SFF, where airflow can be limited. Reference cards can keep other components cooler, at the cost of running a little hotter themselves. If someone was not running SLI, and had decent cooling in their cases, non-reference is the way to go. If you are running SLI and overclocking for super high speed, you should probably consider waterblocks anyways.
My (incomplete) memory overclocking guide:
Does memory speed impact gaming performance? Click here to find out!
On 1/2/2017 at 9:32 PM, MageTank said:
Sometimes, we all need a little inspiration.
