I currently have an air cooled PC in a very old case. I want to upgrade the case because it's not suitable to what I am using the PC for now. It was originally built as a beefy HTPC/TV Gaming machine, but I now use it as a desktop, having acquired a SFF PC for HTPC use. The current case cannot fit particularly large GPUs in and is absolutely terrible for cable routing so the whole thing looks a mess.
So, I want to get a modern case with good cable routing options, plenty of GPU space, and some other modern features like front mounted USB 3.0.
I've narrowed my choices down to three cases.
The Air 240 I like because of its dual chambers, making cable routing easier for somebody like myself who is not so experienced with building. Plus I don't have a modular PSU so I need space to put all the spare cables. I also like the Air 240s aesthetics the best. The white version looks really nice, imo. However, being a mATX case I am limited in motherboard options for future upgrades.
The H440 I quite like the look of, especially the white version with the big window, and it will fit full ATX boards. However apparently space for cable routing behind the motherboard tray is pretty limited, which puts me off a bit.
The Define R5 I'm thinking about for similar reasons to the H440, but I believe it has more cable routing space. I just don't like so much how it looks.
I've not considered the Air 540 as it is simply too expensive.
https://linustechtips.com/topic/515791-help-me-choose-a-case/
the air 240 is the only one of those cases that is actually small
you should never do a dual GPU system for HTPC anyway so matx is perfectly fine
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6859958
Enthoo pro m for the same reasons as above.
Its basically a smaller enthoo pro.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6859959
The Evolv mATX is quite nice too/
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6860033
It's not a HTPC anymore. I am using it as a Desktop. It used to be a HTPC and so it is in a mATX case at the moment. So I am considering an air 240 because I can fit my current mATX system in there. I don't mind that much, however, it'd be nice to be able to consider ATX board for future upgrades.
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6860061
Fractal define S good case and will save you some money
This.
Even though I "upgraded" from the more expensive Corsair Obsidian 750D, I'm in love with my Define S.  I don't need a hundred thousand HDDs and I've barely populated my Storage on the back, but it's super easy to cable manage and gives you literally 400mm of GPU clearance, uninterrupted airflow and frankly is better than the R5 while being less expensive. Like the H440 though, it has no Optical Drives - if that matters.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6860069
This
The Enthoo Pro M is a nice looking case, and can fit a massive air cooler.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6860097
im sort of a fractal fanboy
i love there cases
simple, but sexy looks
great functionality
great quality..
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6860111
This.
I do have an optical drive that I use from time to time, but a lack of a bay is not a deal breaker.
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6860314
Then you should love the Fractal Design Define S.
ATX - big enough for any upgrade path within reason.
Big window - much like the H440
Amazing airflow & cable management - much like the R5.
https://linustechtips.com/topic/515791-help-me-choose-a-case/#findComment-6860879
