Looks alright, I'd personally replace the seagate drive for a wd blue, and get a psu from evga, the g2 line is a good one.
https://linustechtips.com/topic/515673-first-build/#findComment-6858671
http://pcpartpicker.com/p/zkdGyc what do you guys think about this my budget is MAX. 800! Keep in mind that price are different here in holland, i will be buying from a dutch site: www.azerty.nl
Thanks! (Btw the mobo is 112€)
i replied in your original tread
dont need to open another new tread
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/515673-first-build/#findComment-6858672
Looks good. Would squeeze a 120GB SSD in though.
https://linustechtips.com/topic/515673-first-build/#findComment-6858771
Why do you need that extra fan? And yes, get a better PSU from seasonic or evga.
https://linustechtips.com/topic/515673-first-build/#findComment-6858791
