Need help with true 5.1 headset!
Solved by IvIast3r,
well i have Asus Xonar DX PCIe 7.1 Sound Card and i don't regret buying it. the sound quality is much more clear, as in no static.
And as for switching the outputs yes you can just have your headset plugged into the sound card and then your speakers plugged in on the on board audio. Then to switch you would just change your playback device.
as for usb audio i would try to stay away from that.
i am no expert but i am basing everything on what i have owned or what i currently own.
