Help buying headphone cables
Damnit Sennheiser! I love your headphones but the cable is too damn long and the cable is not 3.5mm .
Anybody know any cables i can use in place of the one included? It's for my HD 518s . It uses the 1/4 inch jack instead of 3.5mm and it's 2m long instead of 1m or 0.5m .
Can i buy a shorter cable that'll work with it? And will it be 3.5mm?
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/515007-help-buying-headphone-cables/
Haha I had the exact same problem, I went with the FiiO RC-HD1 - incredible cable, perfect length and well built.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
Does it fit into the headphones? COs i noticed it has a wierd pattern on the included ones.
Should do, it's exactly the same connector.
Sweet! How much do they cost?
And can i buy them off amazon?
I got mine for £25 on Amazon.
WTF! 25 pounds for a damn cable! I spent like 70 on the headphones!
Could you find a cheaper one which will do the job well?
If you were annoyed with the length and adapter as much as I was then it's worth it haha.  Something like this is pretty spot on, braided as werll: http://www.amazon.co.uk/dp/B00T6ET2E6/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B00EUGZVHW&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=10TZR24912FQ0P90TJXP
Sennheiser makes their own 1,2m cable. Just look for 'Sennheiser 505638' It's out of stock but 7,90€. It looks to be a standard 2,5mm 4-pole and 3,5mm 3-pole. You could fin even cheaper cable but I'd find out about the wiring before purchasing.
You can just get a cable with 2.5mm on one end, and 3.5mm on the other. THe headphone side is 2.5mm, the other side is whatever you want, presumably 3.5mm
