No display .... Help!
Go to solution Solved by Brennan Price,
Could you try using DVI or VGA?
hi a  pc owned by my grandad  has been working over display port for the past 6 months and ever since this morning as soon as he  turn on my pc it just says no signal on my
AOC I2769VM monitor and when i tries using hdmi it still says no signal can anybody help me fix this issue? if it helps the specs are
Amd 6300
r7 370
8gb corsair vengeance 2400mhz ram
MSI 970 Gaming mobo
with a 120gb ssd and a 2tb hdd
Any help would be greatly appreciated.
https://linustechtips.com/topic/515003-no-display-help/
