Need Some GPU Help
Go to solution Solved by GlassBomb,
My friend recently got a Zotac GTX 960 and the fan is not spinning. I know that some 960s don't use the fan until the temps hit 60c but I would just like to know if Zotac is one of them and that the card does not have a problem thanks for the help.
Yes, it does comes with this feature.
Every ZOTAC GeForce GTX 960 card comes embedded with the latest breakthrough from ZOTAC - FREEZE technology. FREEZE is an inspired innovation that will enable powerful video cards to become silent and reduce the wear on the fan system. When the user is not in action, the fans idle so users can enjoy the sound that they don't hear.
https://linustechtips.com/topic/514604-need-some-gpu-help/#findComment-6847188
Is he getting video output?
CPU: Intel Xeon E3 1231 V3 3.4ghz CPU COOLER: Cryorig H7 w/ Red Corsair SP120mm  MOBO: MSI SLI Krait Edition Z170 MEMORY: G.Skill Ripjaws 8gb (2x4) Storage: Kingston V300 120gb, WD 1TB GPU: MSI R9 390X CASE: Phantom 410 (ew) PSU: Thermaltake Toughpower Modular 550w CASE FANS: 4 CORSAIR SP120mm MONITOR: LG 25UM67 KEYBOARD: Das4 Ultimate Cherry MX Blue MOUSE: Deathadder Chroma Left-Handed AUDIO: Sennheiser HD598 Black, Astro A40s
https://linustechtips.com/topic/514604-need-some-gpu-help/#findComment-6847189
