Closest you will get is Silverstone  700W at 140mm
http://www.amazon.com/Silverstone-80PLUS-Bronze-Modular-ST70F-PB/dp/B00S5V5C4A
Edit: Fixed my mistaken SFX label
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/514193-help-finding-short-psu/#findComment-6843183
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/514193-help-finding-short-psu/#findComment-6843184
Looking for a short PSU (<160mm) that is 1000W with 4 PCI 8 pin connectors.
Can't find one anywhere
What are you powering? Are you using an SFX form factor?
https://linustechtips.com/topic/514193-help-finding-short-psu/#findComment-6844243
Neither is any 1000W PSU...
No, he linked an ATX PSU and said it was SFX, I was just correcting him.
And the ST1000 from Silverstone is 160mm and 1000W, I don't think he specified if it needed to be SFX or just ATX.
https://linustechtips.com/topic/514193-help-finding-short-psu/#findComment-6844256
