Hi everyone,
I just wanted to know if by adding a new PCI network card I will be able to double local network bandwith by using both onboard LAN and the network card.
I suspect that wouldnt work (especially if it works like onboard graphics/graphics card), but who knows...
If you have any idea, I'm all ears!
Thanks
PS: I'm stuck at 100Mbits on my desktop and I kinda use it as an unconvenient NAS.
Zak'
(Please note that I'm not a fluent english speaker, thus sorry for the poor grammar. However, I'm better in French and Arabic if you wanna communicate via private messages.)
https://linustechtips.com/topic/513936-adding-lan-lanes/
Can't really increase your bandwidth unless you go 10Gbit.
There is a thing called LAG - Link aggregation, but only useful when many people are accessing files at the same time.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/513936-adding-lan-lanes/#findComment-6840758
what you *can* do is add a second NIC, and tell different people to use different NICs.
(example: on-board nic for you and dad, add-in nic for sister and mom)
that said, is your speed limited by your system, or by shitty network equipment?
you mentioned 100Mbit, and i doubt your motherboard isnt gigabit capable.
do you happen to have crappy hubs/switches/routers that cant do gigabit?
https://linustechtips.com/topic/513936-adding-lan-lanes/#findComment-6840800
I'm poorly equiped when it comes to network.
My router/access point is gigabits compatible, but it is very far from my desk. I use PLC (up to 500 Mb/s) for the desktop and 2 smar TVs.
Thanks, digging into it, but it sounds like a headache. :P
Zak'
https://linustechtips.com/topic/513936-adding-lan-lanes/#findComment-6840879
-snip-
Yes but then you will need a switch that supports it, but using two 100Mbps connections is pretty stupid. Assuming perfect scaling, that only adds up to about 20MBps. Far less than your HDD can (probably) read at. Just get a single gigabit network card and use that. It will end up much faster than two 100Mbps connections, it won't require a new switch and extra configuration and it is much less likely to go wrong.
Depends on how you configure it.
https://linustechtips.com/topic/513936-adding-lan-lanes/#findComment-6846256
