First PC Build
Go to solution Solved by Maxxtraxx,
Hres a possibility? Sorry its over 600 without a monitor included but i think it's the minimum 60fps ish at very good quality settings.
HERE
The gta5 performance chart can be found here.
1. Budget & Location
So my budget is around 500 euros-ish, and location, as in my name, Ireland :D
2. Aim
I plan to use this for gaming with my friends, I'd like to run games such as GTA V or H1Z1 60fps on normal settings if possible.
3. Monitors
I still need to get a monitor so any suggestions would be nice around the 100 euro-ish range. (I don't mind response times and all that. Not included with the PC budget.)
4. Peripherals
I still need a keyboard and mouse, although I can get those pretty easily, any keyboard and mouse would do me as long as they work, and look cool. I don't mind response times and all that.
The build I was told to build by my friend was this : http://uk.pcpartpicker.com/p/GfmGpg , so any comments on whether or not to get that would be helpful too. <3
Thanks in advance <3
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
whats that in dollars?
That's just a pcpartpicker link?
Holy Derp http://uk.pcpartpicker.com/p/QRntMp
  Roughly 550 dollars
correct me if im wrong, but the monitor has its separate budget,
~dm
Yeah
HERE
