  Hello guys. I recently encountered a boot problem which i never had anything like this before. If i take it from the beginning, after running Flight Simulator for 2-3 hours i shut down my pc properly. I went out for 3-4 hours and when i came back i tried to power up.
   The normal beep sound and all the things went well until Windows loading screen. The circle that shows loading under Windows logo didnt show up this time. After waiting 5 minutes i restarted the pc using the button on the case and this time after beep sound it stuck at the number "0078"  that shows bottom right of the screen. After waiting a bit it said something like use a USB device or hard drive to boot up ( i dont even remember what it said because i was terrified about losing my hdd) I tried it again and it did the same thing .
   Then i unplugged the whole computer and checked for any power cable that not in . It was normal. I un-plugged and plugged back the power cord for hdd. And i switched my HDD Data cable for another slot.
   After that i powered up the computer and i went smooth as normal.
   My question is , what may caused this problem and do i need to back my things up and switch up my HDD ?
   I do have a almost 6-7 years old Samsung HD103SJ 1TB HDD and MSI 770-C45 motherboard. Just a moment ago i downloaded CrystalDiskInfo and it says Health status: Good Power On Hours:15787 (wow) I will add the log i took from the app.
  I called Samsung but they said i need to talk with Seagate which they are in Christmas Holiday . I'm waiting for help guys thanks !
EDIT: BTW  I 'm having some grindy noise coming from PC (cases one of the side is open) for a while now . I dont know its coming from HDD or not.
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 _51 000000000009 Read Error Rate
02 252 252 __0 000000000000 Throughput Performance
03 _71 _65 _25 00000000233D Spin-Up Time
04 _97 _97 __0 000000000C3B Start/Stop Count
05 252 252 _10 000000000000 Reallocated Sectors Count
07 252 252 _51 000000000000 Seek Error Rate
08 252 252 _15 000000000000 Seek Time Performance
09 100 100 __0 000000003DAB Power-On Hours
0A 252 252 _51 000000000000 Spin Retry Count
0B 252 252 __0 000000000000 Recalibration Retries
0C _97 _97 __0 000000000BEA Power Cycle Count
BF 100 100 __0 00000000000A G-Sense Error Rate
C0 252 252 __0 000000000000 Power-off Retract Count
C2 _64 _56 __0 002C000E001A Temperature
C3 100 100 __0 000000000000 Hardware ECC recovered
C4 252 252 __0 000000000000 Reallocation Event Count
C5 252 252 __0 000000000000 Current Pending Sector Count
C6 252 252 __0 000000000000 Uncorrectable Sector Count
C7 _91 _91 __0 0000000012C6 UltraDMA CRC Error Count
C8 100 _99 __0 000000007EB7 Write Error Rate
DF 252 252 __0 000000000000 Load/Unload Retry Count
E1 100 100 __0 000000000C5D Load/Unload Cycle Count
https://linustechtips.com/topic/512756-is-this-a-hdd-problem-or-not/
If your S.M.A.R.T reports are all in green,or it says its status is Good then its probably fine.That grinding noise is pretty disturbing tho,make sure it aint coming from the HDD itself,that indicates a drive failure.
Shark Rampage V: AMD FX-4350 @ 4.5GHz(1.404 Volts) / Hyper 212 Evo / Gigabyte 750Ti (1405MHz Core,3200MHz Memory @ stock voltage) / Kington HyperX Fury 8 Gigs 1866MHz Dual channel / ASUS M5A97 R2.0 / WD Caviar Blue 1TB 7200 RPM / 850Evo 250GB / XFX TS 550w 80+ Bronze Sharkoon VG4-W
Thanks for your answers. I thought the same thing. If its good why its making sound like this. While i was backing up all the important stuff i noticed that when the disk usage is over %80 or %90 that sounds come in. So its sadly HDD i think .
