LEDs under motherboard... Problem?
Solved by W-L,
-SNIP-
It shouldn't have any problems as long as your standoff's are tall enough and being the waterproof LED's it will protect itself and the motherboard solder point form making contact. Double check to make sure the connection point of the LED's and wires are solid and nothing is pushing against them which may cause a bad connection with one of the 4 pins.
