Cheapest CPU Cooler
Go to solution Solved by Amazingasian,
Yea i looked at that one when i was gonna build the pc myself. But now imma probs just let pbtech do it which is $40. Are there any good psu's from here http://www.pbtech.co.nz/index.php?z=c&p=psu or here https://www.mightyape.co.nz/Computers/Components/PSUs that won't go ka boom
Corsair RM, RMi, HX, AX, EVGA G2, P2, any Seasonic.
When in doubt, check against this:  http://linustechtips.com/main/topic/404921-strmfrmxmns-psu-whitelist/
http://nz.pcpartpicker.com/p/LNPj6h
Heyy so just found out the skylakes don't have stock coolers :l and i don't know what else i can cut down on to save money... so can someone please offer me a cheap cpu cooler but won't have a risk of overheating.
I don't plan on overclocking.
Thanks
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/
Thanks
Buy an intel stock cooler off ebay or a Hyper 212 Evo.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803604
Thanks
Switched out the PSU for one that won't blow up.  The locked CPU's do have coolers.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803619
Thanks
http://www.pcforce.co.nz/deepcool-gammaxx-300-p-3353.html
Edit: it should come with a cooler, I forgot.
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803620
So the i5 6500 will have one? http://pricespy.co.nz/product.php?e=3287020
Only the unlocked cpu's don't come with a cooler (6600k for i5)
"Graphics and gameplay are not mutually exclusive."
"Nvidia, AMD, Intel, or whatever company out there has only one end goal and that is PROFIT.
If you think these companies exist for any other reason you're gonna be disappointed my dear. CAVEAT EMPTOR"
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803652
Why would it blow up? What would i get instead :l
The NEX are bad PSUs.  The seasonic is way better.
Power Supply: SeaSonic 550W 80+ Gold Certified ATX Power Supply  ($154.64 @ Ascent Technology)
Optical Drive: Asus DRW-24D3ST DVD/CD Writer  ($40.00)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($184.00)
Total: $1458.64
Generated by PCPartPicker 2015-12-22 16:16 NZDT+1300
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803665
212 evo
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803667
Even if the locked Skylake chips come with coolers, I recommend getting a 212 EVO, things a beast, has managed to cool my 4690K even with a heavy overclock.
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803680
Total: $1458.64
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803710
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803722
Yes, the 6500 will have an cooler too. I recently built a system with one, so I can verify that they do indeed come with a cooler.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/510244-cheapest-cpu-cooler/#findComment-6803819
