So I'm charging my phone using wall power and as usual I charge my phone and use it at the same time and everything is normally fine except it take a little longer to charging.
Usual time takes around 1:30hrs to charge to full maybe 2hrs to charge it full while using it. I left my phone on charge for 30mins and it only charged 18% without using it.
I thought nothing of it and used it while it charged (watching YouTube) and it slowly dropped from 57% to 50% still charging from the wall.
Phone is a Huawei P8 Lite (2ish months old) and using stock stuff to charge
Does anyone know what is going on and what I can do to fix this?
Thanks
Do you play football/soccer?
Cause you look like a left-back
https://linustechtips.com/topic/509684-losing-power-while-charging/
Do you have any other devices you can plug into the adapter?
this is a sign the battery inside the phone is dying
or your adapter needs to be replaced
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
My phone is the only one in my family to use this USB connection. Everyone uses apple
The USB port on the adapter is universal. Apple devices include a similar adapter, though the capabilities may be different.
@dragoon20005 phone is only a couple months old really?
Also do you know how I can quote reply on mobile
what is the Amps on the adapter?
Stock adapter output 5V 1A
Okay. Then try connecting your phone directly to your PC and see if it charges.
Click into the post and quote wil show up.
Your issue can have two reasons:
- Charger is bad and deliver to less current. I can carge my phone with 4.5 volt and 10 mA. It takes foreve, nevertheless it allwas say it is charging.
- charging circuit or the battery itself on your phone is damaged (unlikely).
The apple chargers also have an usb port. You can use them and your cable to test.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
Okay. Then try connecting your phone directly to your computer and see if it charges.
It charges on the brick as well just it losing power during use and charging. Dont have comp till next months :/ old one broke using christmas money to get a new one
how is your phone usage patterns?
are you running full brightness and speaker at max volume?
Youtube + Wifi + full brightness and speaker at max volume are battery drainers
- Charger is bad and deliver to less current. I can carge my phine with 4.5 volt and 10 mA. It takes foreve, nevertheless it allwas say it is charging.
Seeing this I have dropped my phone a whole lotta time whilst I've had it. Maybe this has done something to the internal battery?
3/4 or half brightness and wifi and youtube
Damaged electronics by dropping usually gives up completly. It's not getting slower. Also the battery is not very sensitive to mecanical shock.
Also most phones can opperate with no battery at all when wall power is used. It should not drain the battery when the charger can deliver 5 watt.
Could this be a cable issue?
When a data line is broken, the current will be limitted to 0,5 A what is still 2,5 watts. This should still be enougth. To test you can connect to smarphone to the PC. If you can transmitt data it's fine.
