Does the forum keep going down?
TheSLSAMG
All up there.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
Yes. although not as much as the vbulletin5 days, or "the dark ages" as it should be called.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
It does occasionally go into cloudflare mode so keep that in mind ^_^
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
Just went down and went back up for me...
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
Okay, thanks guys. I just wanted to make sure it wasn't my internet.
Yeah, every time it goes down for me (5-8 times a week) it's back up within minutes, sometimes all it takes is a refresh.
01110100 01101000 01100101 00100000 01110001 01110101 01101001 01100101 01110100 01100101 01110010 00100000 01111001 01101111 01110101 00100000 01100010 01100101 01100011 01101111 01101101 01100101 00101100 00100000 01110100 01101000 01100101 00100000 01101101 01101111 01110010 01100101 00100000 01111001 01101111 01110101 00100000 01100001 01110010 01100101 00100000 01100001 01100010 01101100 01100101 00100000 01110100 01101111 00100000 01101000 01100101 01100001 01110010
I've had the occasional slowdown, but haven't had an outright failure to connect in a long, long time.
Linus & Co. have done a great job with the forum! <3
GW2: Vettexl.9726
I've noticed a lot of forums that use Cloudflare have a habbit of appearing offline a lot.
It appears to me maybe Cloudflare might have something to do with it?
Never went down on me. Looks like Linus' marriage to the forum is going "well".
