CPU And GPU Temps
Go to solution Solved by SeanAngelo,
I Was running some temps and I wanted to check that these are okay temps.
GTX 960: 73C (Under Load maximum normally hangs around 65-69)
I5 4440:  55C (Under heavy load)
These are both stock coolers and with only 1 case fan 3 are arriving tomorrow and i'm planning on liquid cooling it, I just wanted to  check that these temps are okay and what would be the maximum because I cant find it online.
Regards
Chris.
perfectly fine for temp
Regards
Chris.
https://linustechtips.com/topic/508152-cpu-and-gpu-temps/
yup perfectly fine
https://linustechtips.com/topic/508152-cpu-and-gpu-temps/#findComment-6779978
Regards
Chris.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/508152-cpu-and-gpu-temps/#findComment-6779991
