Intel i5 G3258
EVGA 500 W PSU
HyperX FURY 8GB DDR3 1600Mhz
NZXT Source S340
Sandisk SSD 250GB
2 x Corsair AF120's
2x NZXT Fans
Gigabyte H81M-S2H Motherboard
So ive just finished building this PC. I've tried booting with an iso USB plugged it along with keyboard and mouse.
I've tried HDMI and DVI, neither are showing any display.
CPU plug is in, 24pin is in, everything is brand new from Amazon and i dont have any other things to test it with as my PC is DDR4 X99.
Halp.
                                                      Professional Graphics Designer | Case: NZXT Phantom Orange and Black | Motherboard: MSI SLI PLUS X99S
        CPU: Intel i7 5820K | Graphics Card: Zotac nVidia 1080 AMP!
                                   RAM: Corsair Vengeance 16GB DDR4 2400Mhz | Storage: Samsung 850 PRO 256GB, Western Digital Black 3TB & Western Digital Red 3TB |
                                                        Monitors: Acer Predator XB271HU 27", Acer Predator XB270HAbprz 27" and BenQ GL240 24" | PSU: Corsair AX860i |
https://linustechtips.com/topic/508144-first-post-wont-post/
i5 G3258? Either you have a Core i5 or Pentium CPU.
https://linustechtips.com/topic/508144-first-post-wont-post/#findComment-6779875
'i5 G3258'
Really.
Have you got the CPU power plugged in? Is the RAM properly seated?
wat?
Does it POST? Do the fans start spinning?
I done fucked up. Yeah pentium xD
the RAM is clicked into place.
All fans including cooler fan spins.
Case LED lights up.
Mouse LEDs light up once plugged in.
Keyboard LEDs however dont light up at all so powers going through the system just not posting and allowing drivers to load.
https://linustechtips.com/topic/508144-first-post-wont-post/#findComment-6779888
Did you mix the GPU and CPU power up?  Also, said CPU doesn't exist.  You have a Pentium, not an i5.
I dont have a gpu yet. Im using onboard graphics. So the HDMI/DVI was plugged into the motherboard seperatly. Neither loaded an image.
https://linustechtips.com/topic/508144-first-post-wont-post/#findComment-6779894
Usually this is a ram related issue
Try one dimm in the first slot on your motherboard
i only have 1 stick seated
https://linustechtips.com/topic/508144-first-post-wont-post/#findComment-6779928
stick it in a different seat
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/508144-first-post-wont-post/#findComment-6779997
Still try reseating it, it can often look in but be ever so slightly out.
wat?
'i5 G3258'
Really.
Reseated RAM. Still no signal being displayed, still not LED light up on Keyboard.
Heres a video of inside the case, see if you can see anything wrong; https://www.youtube.com/watch?v=-XVu-whhYWI
Still nothing
https://linustechtips.com/topic/508144-first-post-wont-post/#findComment-6780061
Did you try running the system ontop of a box or something before installing it in the case? Did you make sure to install the spacers between case frame and mobo?  Also remove everything you don't need to boot to bios, so HDD and network card, audio pin heads ect (And anything else I may have missed from the video) and try again.
If this still fails I think its either your motherboard, or your RAM, and if you don't have any spares I'm not sure how you can test it. Sorry.
https://linustechtips.com/topic/508144-first-post-wont-post/#findComment-6780250
I've just taken it all out. At tried with my ax860i that I know works along with them cables. Still nothing. Spacers between motherboard and case are installed. Tested as well without ssd, keyboard, mouse, USB header, corsair fans. Still no response.
https://linustechtips.com/topic/508144-first-post-wont-post/#findComment-6780529
