Between 3 CPU coolers, need your help!
Go to solution Solved by Luckris,
I got the Hyper 212 PLUS for 18.88 on amazon today. If you ask me that's better than 30$ for around the same performance as the EVO. I can just add some SP 120's to it later, and be fine with temps.
Works out for me, because even if I did buy the EVO, I would just replace the fans anyway. So the only thing I'm paying for really is the heat pipes on the bottom touching or having a gap. And when it comes down to 18$ VS 30$, paying less would be the better solution. Thanks for the advice guys, almost bought the T4.
So I decided that my i7 is getting a bit too hot for my stock cooler, and I need something cheap, in the 25$ range to replace it.
I got 3 on my mind right now;
(Newegg compare link)
 http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=hyper%20212&bop=And&CompareItemList=-1%7C35-233-082%5E35-233-082-TS%2C35-103-182%5E35-103-182-TS%2C35-103-065%5E35-103-065-TS&percm=35-103-065%3A%24%24%24%24%24%24%24
Cooler Master Hyper T4
Xigmatek Gaia SD1283
Cooler Master Hyper 212 PLUS
I can look up all the YouTube and Google reviews of these that I can find, but I still don't know which one would be the best.
I'm looking to overclock a little from my current 2.8GHz, to around 3GHz or more with an i7 860.
I honestly don't know which is the best, hoping people who maybe had experiences with these coolers can help me decide which is the best for what I'm looking to do.
If you know any cooler that fits the 25$ ish price range, and is better always post it.
Thanks for anybody willing to help me out, and I will leave you a pic of my rig to laugh at. Maybe even be disgusted by it... It's bad is what I'm getting at.
https://twitter.com/Avronick/status/334493531152461826/photo/1
https://linustechtips.com/topic/50755-between-3-cpu-coolers-need-your-help/
Get the 212 EVO
Its $5 more than the Plus but it performs a ton better
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
I'd go with the hyper 212.
The T4 has lower FPI and the gaia has only 3 heatpipes.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
212 Evo would be my choice.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
Alright, I'll look into the 212 Evo. I was just going to buy a back plate for my GTX 470, so that's why I was looking for the price range of like 25$. I'm sure I can spare a few more dollars though.
Thanks for your help guys. I was originally going for the Hyper T4, but 212 Evo is it!
the hyper212 evo is a great cooler with one of the worst mounting systems ever.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
Get the Hyper 212 EVO
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
I would go with the Hyper 212 Evo also.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
Looked into it a bit more, and the Evo really doesn't offer much more performance for the budget I'm in. I'm going with the 212 Plus tomorrow, and then later saving more and buying a few Corsair SP 120 fans to help it along.
After that I will get a Backplate for my 470, then a I/O shield for my mobo, and to finish it all off, a new PSU, and maybe get rid of that horrid internet card that always gives me issues. After that, it's all going to go towards an Air 540, with a H100 or something.
Only advantage of the Evo, is the new fan, and the heat pipes all touching, which really only offers a 1-2 difference.
I guess I might be the only one, but the xigmatek cooler has treated me pretty well, and was really easy to mount.
"Her tsundere ratio is 8:2. So don't think you could see her dere side so easily."
Planing to make you debut here on the forums? Read Me First!
unofficial LTT Anime Club Heaven Society
I was literally expecting a flood of Hyper 212 EVO ...
So I couldn't tell much of a difference between the Hyper T4, and the 212 Plus. I'm guessing the T4 just doesn't do as well. I couldn't find any good comparisons between the two either.
http://dvtests.com/?p=11083
The Evo is a bit better at idle and even more so when overclocked or under load.
