Hi people!!
I recently bought a Hard Drive and some Ram with the view to build my own PC. I wasn't massively thinking at the time, just spending a little birthday cash. But I was wondering what you guys think of my proposed build? I don;t need it to do a lot. In fact, all I do is:
Watch YouTube videos
Code websites (only with HTML and CSS at the moment using Sublime Text....still a massive newb)
Play Football Manager 2016 (At least I would if this laptop wasn't so old and shoddy!!)
Use Microsoft Word and Excel
So, as you can see, no real need for dedicated graphics card or anything fancy (that may come when money improves)
CPU: AMD A6-7400K 3.5GHz Dual-Core Processor  (£44.92 @ CCL Computers)
Motherboard: ASRock FM2A68M-HD+ Micro ATX FM2+ Motherboard  (£37.03 @ CCL Computers)
Memory: Crucial 4GB (2 x 2GB) DDR3-1600 Memory  (Purchased For £12.98)
Storage: Seagate Barracuda 750GB 3.5" 7200RPM Internal Hard Drive  (Purchased For £22.49)
Case: Zalman ZM-T4 MicroATX Mini Tower Case  (£20.02 @ CCL Computers)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£29.99 @ Aria PC)
Total: £167.43
Generated by PCPartPicker 2015-12-17 20:53 GMT+0000
My current laptop: HP Compaq Presario CQ62
https://linustechtips.com/topic/507402-first-build/
Hi people!!
Get rid of the case and upgrade to at least an A8 7600, or possibly go for the A8 7650k, next upgrade you'll want is to get the fastest 8GB kit you can for the lowest price
like:
http://uk.pcpartpicker.com/part/gskill-memory-f317000cl11d8gbxl
PCPartPicker part list: http://uk.pcpartpicker.com/p/PzDsdC
Price breakdown by merchant: http://uk.pcpartpicker.com/p/PzDsdC/by_merchant/
CPU: AMD A8-7600 3.1GHz Quad-Core Processor  (£64.45 @ CCL Computers)
Motherboard: Gigabyte GA-F2A78M-D3H Micro ATX FM2+ Motherboard  (£40.28 @ More Computers)
Total: £170.19
Generated by PCPartPicker 2015-12-17 20:59 GMT+0000
https://linustechtips.com/topic/507402-first-build/#findComment-6771529
Is definetly not amazing, but it's definitely a good little build you should be able to add a decent graphics card to if you plan on gaming.
*sorry, voice to text
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/507402-first-build/#findComment-6771530
Would I need that for my limited use??
Cheers.
https://linustechtips.com/topic/507402-first-build/#findComment-6771549
Motherboard: Gigabyte GA-F2A68HM-HD2 Micro ATX FM2+ Motherboard  (£32.99 @ Aria PC)
Total: £127.43
Generated by PCPartPicker 2015-12-17 21:01 GMT+0000
Don't need a case, RAM and HDD already bought.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/507402-first-build/#findComment-6771557
Total: £127.43
Cheers. I assume I could use an old PC case if I have one around from my old Dell Desktop PC? Provided the mobo fits?
https://linustechtips.com/topic/507402-first-build/#findComment-6771572
Because I wouldn't recommend a dual core much in this day and age, and in addition the A8 7600 can play games well at 720p ish if you ever delve into more gaming. Which I'd imagine will probably happen now
https://linustechtips.com/topic/507402-first-build/#findComment-6771743
Ahh that makes sense! Cheers.
https://linustechtips.com/topic/507402-first-build/#findComment-6771986
