Cheap sound card for microphone preamp?
Solved by ShadowCaptain,
Correct, the microphone is connected via XLR, and I use a DYI cable that converts it to 3.5mm. Would the card that @Xenift suggested work? I was hoping I could use something inside the computer, and not having to carry it externally.
You can get XLR to USB cables which would probably be a better idea
I dont know of any cards that take in XLR, a proper XLR interface is so much better - also with these external devices you can get the microphone to mix into your headphones for real time monitoring - and control the mic mid stream/game
Would a sound card work? Maybe, I am not sure if they have any mic pre-amps as they are normally focused on audio OUT - but maybe something you can check on!
