This:
PCPartPicker part list: http://pcpartpicker.com/p/MD8XJx
Price breakdown by merchant: http://pcpartpicker.com/p/MD8XJx/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($213.99 @ SuperBiiz)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  ($59.00 @ Amazon)
Total: $272.99
Generated by PCPartPicker 2015-12-16 07:26 EST-0500
https://linustechtips.com/topic/506528-need-help-fast/#findComment-6760655
XFX PSUs are <3
srsly tho.
Shark Rampage V: AMD FX-4350 @ 4.5GHz(1.404 Volts) / Hyper 212 Evo / Gigabyte 750Ti (1405MHz Core,3200MHz Memory @ stock voltage) / Kington HyperX Fury 8 Gigs 1866MHz Dual channel / ASUS M5A97 R2.0 / WD Caviar Blue 1TB 7200 RPM / 850Evo 250GB / XFX TS 550w 80+ Bronze Sharkoon VG4-W
https://linustechtips.com/topic/506528-need-help-fast/#findComment-6760711
Hi!
So i have two decisions
Go with i5-4460 and evga gs 550w
Or with i5-4690k and evga 500B
4690k and a 550W PSU
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/506528-need-help-fast/#findComment-6760712
