Keep it or Swap it?
I do not NEED to switch, i play every game just fine at High settings 1080 60FPS.. (Not Arma/Dayz since that works better on Intel i guess).
But since i have been active on this forum i only hear BAD shit about AMD when it comes to it performing against even the lower tier Intel chips..
So thats why i was wondering if it really is so bad to have a 8350 instead of a decent i5 or i7.
If you're happy with the performance, you're happy with the performance. Shouldn't matter what anyone says/believes, people may point out that it was a poor choice (which it was) but that shouldn't change your stance that for you AMD hardware works.
A good friend of mine at work has 2 AMD FX systems, which I happily point out as boggling my mind given his expertise with most things electronic, but his main point was that he was happy with the performance of his system and he had fun building it, he could give two shits about what anyone else thought.
