First post here, but have been watching Linustechtips for years. Be kind?
http://au.pcpartpicker.com/p/JQbDP6
CPU+Cooler
Intel Core i7-6700K 4.0GHz Quad-Core Processor
Corsair H110i GTX 104.7 CFM Liquid CPU Cooler
Motherboard+Ram
Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard
Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory
Storage
Samsung 850 EVO-Series 500GB 2.5" Solid State Drive
Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive
Video Card (reusing from previous build)
Gigabyte GeForce GTX 780 Ti 3GB WINDFORCE Video Card
Case and Power Supply
Corsair Air 540 ATX Mid Tower Case
Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply
My questions are pretty simple.
Am I getting the most for my money?
Is the ram a good choice?
4x8b sticks or 2x16gb sticks?
Am I better off with a different motherboard?
Should I go with a Corsair 850w or 750w power supply instead? (hoping to upgrade the graphics card 3Q 2016 to the new Nvidia Pascal card)
The aim of the rig is to future proof my gaming for the next few years. Have I hit the mark here, or is there room for improvement? Since I am Australian, everything costs more here... please try and keep that in mind if there is something I should change.
I submit myself to your ridicule.  B)
https://linustechtips.com/topic/506284-i7-6700k-build-help/
This is better, a faster CPU, no need for 32GB of RAM, and no need for a 1000W power supply, a 850W is more than enough even for going two power hungry GPUs:
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($569.00 @ Storm Computers)
CPU Cooler: Phanteks PH-TC14PE 78.1 CFM CPU Cooler  ($99.00 @ PCCaseGear)
Motherboard: MSI X99S SLI Krait ATX LGA2011-3 Motherboard  ($329.00 @ CPL Online)
Memory: G.Skill Ripjaws Series 16GB (4 x 4GB) DDR4-2400 Memory  ($152.00 @ IJK)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($235.00 @ IJK)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($170.00 @ Centre Com)
Case: Corsair Air 540 ATX Mid Tower Case  ($195.00 @ CPL Online)
Power Supply: XFX PRO Black Edition 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($179.00 @ CPL Online)
Operating System: Microsoft Windows 10 Pro OEM (64-bit)
Total: $1928.00
Generated by PCPartPicker 2015-12-16 12:26 AEDT+1100
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/506284-i7-6700k-build-help/#findComment-6757693
I went with quad channel DDR4 2133 for my Skylake build, and should I ever want to upgrade the RAM, I have to buy a whole new kit. Something to keep in mind.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/506284-i7-6700k-build-help/#findComment-6757698
But Skylake is only dual channel.
https://linustechtips.com/topic/506284-i7-6700k-build-help/#findComment-6757726
I'm mixed up then. I have four sticks of 4GB, each with their own slot; is what I mean. Point still stands, though, I'm stuck without changing all four sticks for higher capacity dimms.
https://linustechtips.com/topic/506284-i7-6700k-build-help/#findComment-6757738
CPU+Cooler
Motherboard+Ram
Storage
It looks good to me. However, you don't need 32GB of RAM just for gaming. Hell, you probably wouldn't need that much if you were rendering. 16GB is the high end sweet spot right now and will be into the future. Normally I would say that a 750w would be good,but I would go with the 850w PSU because I read that the pascal cards are going to be seriously power hungry compared to this generation. Other than that, you can't go wrong with any of it. All of these specs are balanced for your specific needs I assume.
https://linustechtips.com/topic/506284-i7-6700k-build-help/#findComment-6757755
Would https://au.pcpartpicker.com/part/corsair-memory-cmk16gx4m4b3466c16 be a happy medium?
I am running 3 monitors and at times rendering videos. Don't know if that changes anything.
From what I am hearing a 850w or 1000w power supply would be the go for me. The plan is to at least run 2 Pascal's in SLI.
I assume the bottleneck will be the CPU for most if not all games. Is the i7-5820K Morgan recommended a better CPU?
https://linustechtips.com/topic/506284-i7-6700k-build-help/#findComment-6758422
It is still not a reason for you to spend money that you will never utilize.
if your psu is sitting idle, it wont need its fan, so it runs silent.
if you're into that, its something to consider.
https://linustechtips.com/topic/506284-i7-6700k-build-help/#findComment-6758574
