NZXT S340 + CM 212 EVO = Fit?
iNoa97
Does the CM 212 EVO actually fit in the S340? I think I may have seen a couple builds with it, but im not really sure.
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
Yep , the S340 supports up to 161mm CPU coolers. The Hyper 212 EVO is 159mm so it should fit.
CPU: AMD Ryzen 5800X GPU: Nvidia RTX 3080 12GB + Motherboard: Asus Crosshair VIII Hero
  Case: Asus ROG Strix Helios Gundam Edition Power Supply: Asus ROG Thor 850P
yes it does.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
It will fit fine.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
