I am using a i7 2600K Sandy Bridge with 8gbs ram
Was thinking of changing my GFX from GTX 760 to GTX 970.
Is it a good choice? WIll I face bottleneck from my cpu?
Reason is some games are hard to play now with my GTX760 (Laggy)
It will be a good upgrade.
There is always a bottleneck SOMEWHERE. But no, that wont be a huge bottleneck at all.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/505550-upgrade-help/#findComment-6747627
CPU/RAM should be fine, but I'd suggest a 390 over a 970, it has 125% more VRAM, bit more performance overall, potentially better DX12/Vulkan support, but mostly you save money on free-sync vs G-sync
https://linustechtips.com/topic/505550-upgrade-help/#findComment-6747894
But 390 from where i am at is very expensive.
$589SGD
https://linustechtips.com/topic/505550-upgrade-help/#findComment-6748105
Think with my budget I can only got MSI 960 4gb
Should check if the 380 is the same price, or check the price of 200 series cards
https://linustechtips.com/topic/505550-upgrade-help/#findComment-6750602
Are those better?
the 380 is a bit better overall ya, and the 290 would be the last gen card to get
mostly it's just for potentially better DX12/Vulkan support, and a cheaper adaptive sync display
https://linustechtips.com/topic/505550-upgrade-help/#findComment-6750886
