So I recently purchased R9 280x from the pc part shop here in our place for about $120. I wanted to test it and compare benchmark so I downloaded 3dmark.
Right when I clicked "Run" it froze at the same exact moment,.
Here I took photo with my smartphone..
I forced shutdown my PC because it never came back.
Please help me.
CPU: Ryzen 7 5800X | MOBO: Gigabyte B550 Vision D | RAM: Crucial Ballistix RGB 32GB 3600MHz | GPU: Gigabyte RTX 3070 Vision D | PSU: Seasonic Focus+ Gold 750W
https://linustechtips.com/topic/505155-3dmark-fire-strike-please-help/
try it again? it only happened once?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
did you install the latest AMD crimson drivers?
what was the previous card?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I havent tried it again because im curious why does it have to happen? Everything in my PC is new except the Graphics Card I bought,
Yes I downloaded it from AMDs website. All my components are new.. I used the Dedicated GPU for just 1 day and bought this 280x card on sale.
Check for any updates for the drivers, if not, run other games on the card to see whether there is any artifacting whatsoever.
If there is artifacting, then RMA the card, if not then there is another problem somewhere else.
How will I know if there is artifacting? The best GPU I have used so far is HD 7750. I havent played any AAA games so maybe I cant tell the difference.
make sure you got the version is the Beta version
Well if there is flickering and white spots or things that seem irregular.
I dont have the Beta Version.. What's the difference? Beta means it's still on testing state right? Does the official release have problems?
FS is more for Highend Cards btw.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
I saw some benchmarks on R9 280x with Fire Strike. I just want to compare if I'll get a score near theirs.
Not at all, FS is designed to run on desktop systems, Sky Dive is designed for Smart Phones and Tablets while Cloud Gate is designed for Laptop and Netbooks with iGPUs.
Main Rig:-
Server:-
the hotfix version fix issue with the driver locking fan speed at 20%
Try again and see if it still freezes, if it still does maybe perhaps try testing with a different game / benchmark like unigine valley or something.
If those don't work either, maybe try a different driver or maybe something in your windows install is messed up.
:rolleyes:
FS is designed for high performance Gaming PC´s.
SD for midrange Gaming PC´s.
Tried it again and froze again. :(
What are the possibilities that I got a bad card? This card only has 1 month warranty.
Does it work in other applications / games?
So far the only one I have here is Dota2. It seems to work. Well even the Dedicated GPU works with Dota2. I am currently downloading Unigine Heaven. I hope there's no problem in the card because it's a big hassle to return the card. And the shop where I bought this from seemed not so friendly.
