My intake fan on my H80i gt push-pull config randomly stopped died. Checked the splitter fan cable and it is not the problem. so it looks like I need a new fan. What is a good static pressure fan that isnt too terribly loud to replace the stock SP120 fans that come with the H80i GT? Any help deciding would be much appreciated.
https://linustechtips.com/topic/504288-h80i-gt-fan-replacement/
Accidentally posted on the wrong account, this is the account you should message me to if you need.
CPU:i7 4790k @4.4 GHz, Motherboard:ASUS Z97 Pro Gamer, RAM:8GB DDR3 1333 MHz (2x4GB), GPU:R9 380 4GB Sapphire Nitro,
Case:HAF 912, SSD:240 GB PNY CS1100, Mass HDD:1TB WD Blue, PSU:Rosewill 750W 80+ Bronze, Monitor:HP 2311X 60Hz 1080p,
CPU Cooler:H80i GT (AS5 Thermal Paste), Keyboard:Corsair K30, Mouse:Logitech G500s, Operating System:Windows 10 64-Bit
https://linustechtips.com/topic/504288-h80i-gt-fan-replacement/#findComment-6731929
So since nobody wants to suggest anything, i have decided between the SP120 PWM Quiet Edition or Performance edition, which should i choose?
https://linustechtips.com/topic/504288-h80i-gt-fan-replacement/#findComment-6732416
