Best GPU for LAN Party PC
Go to solution Solved by ashypanda,
it might be worth looking at open box or B-stock as they are still new just with a extra discount.
I'm planning to make a few lan party machines for my home which can run most games at medium-high settings. I currently am running a Sapphire R9 270X and I can near max out any game at 30-60fps and I would like to get a card similar to it but cheaper and hopefully Nvidia. I was thinking about the 750 Ti as it is £100 over the 270X being £160 and its similar in performance.
So my question is, what card should I get? The machines are going to be pretty low end but good enough to play games like gta, smite etc.
https://linustechtips.com/topic/504101-best-gpu-for-lan-party-pc/
I would say get a GTX 950 on sale.
Any 950 you can get for under $150 US is a good deal. https://uk.pcpartpicker.com/parts/video-card/#c=329&sort=a8&page=1
($150 is what the 750Ti was originally priced at 1-2 years ago)
I also think it's a bad idea to get a card that is already 2 years old.
One deal to consider if you are into Heroes of the Storm is this one on Newegg for $140 after rebate with free Heroes of the Storm stuff and a free plushie for cuddling with in the Winter: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121981&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Otherwise I would go for this deal of it for slightly less cost:
http://www.superbiiz.com/detail.php?name=AS-950M2GD&c=CJ
edit: nvm just realized you are not in the US whoops. Silly me reading too fast. Changed pcpartpicker link above to compensate
A society's accepted views of the world surrounding said society is both the making and undoing of society itself.
“While one person hesitates because he feels inferior, the other is busy making mistakes and becoming superior.” - Henry C. Link
if you're after a GPU just for those games, you can get a new 2gb 380 for £120, which for mobas and games like CS:GO it's near perfect.
Intel i5-6600K@4.2GHz, 16GB Crucial DDR4-2133, Gigabyte Z170X-UD3, Be quiet shadow rock slim, Sapphire RX 480 Nitro+ OC, Fractal design Integra M 550W, NZXT S340, Sandisk X110 128GB, WD black 750GB, Seagate momentus 160GB, HGST 160GB
R9 380X
it will play every game known to mankind that has been released, and will be released for quite a while
Any 950 you can get for under $150 is a good deal. https://pcpartpicker.com/parts/video-card/#c=329&sort=a8&page=1
Otherwise I would go for this deal of it for slightly less:
Hmm ok... I just checked the 950, its £105 whilst the 960 is £140. Which one would you recommend?
R9 380X
That might be good but its near double the budget. Im currently thinking about a 960 at £140 or your suggestion the R9 380X for £190
put of a 950 and 960 i'd go for a 960, as a R9 270x is a bit faster than a 950.
Alright thanks. Probably will go for it. Its a bit over my budget but I think it'll be fine.
If you're thinking 960 get an R9 380 instead, should be cheaper (EDIT: dammit it isn't) but has much better performance (10-15% more). https://uk.pcpartpicker.com/part/xfx-video-card-r9380p2df5
USEFUL LINKS:
PSU Tier List F@H stats
