Hello, Im new to this forum so here is what I would like to know your thoughts on which PSU I should get for my rig;
1. Budget & Location
USD$2000 - 2800
2. Aim
Gaming such as BF3 Crysis 3 World of Warcraft SC2 etc. 1 or 2 VMs
3. Monitors
Right now I'm using a Samsung 40" LED TV as my monitor. I might go for Tri monitor setup but it wont be on this year. I plan on using either 23" or 27" monitors later on
4. Peripherals
Just the CPU. I already have a mech keyboard, game pad and mouse.
5. Why are you upgrading?
My current system is still an i3-540 and I think it is time to upgrade my PC plus I want to try out watercooling.
Specs:
Original specs:
Intel Core i5-4670K
Corsair H100i
Gigabyte GA-Z87X-UD3H
GeForce GTX 780
16GB Corsair Vengeance
120GB Samsung 840 Series SSD
1TB Western Digital Caviar Black
but I gave it some thought and changed it to this;
Intel Core i7-4770K
Corsair H100i
Gigabyte Sniper 5
GeForce GTX 780
16GB Corsair Vengeance/Dominator
1TB Western Digital Caviar Black Hard Drive
AX860i PSU
Color Scheme : Green / Black
Case : Corsair 900D [i already have this]
I can afford to change the AX860i to AX1200i, I know this would be overkill but I also plan to do SLI probably next year when the 780 is a bit cheaper and go for a full watercooled setup. Let me know your thoughts :)
I also plan to have around 7 HDDs and 2 SSDs later thats why I'm thinking of getting the 1200W one.
https://linustechtips.com/topic/50378-need-suggestionsrecommendations-for-psu/
860 is more than enough for SLI
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
An ax760i is already enough for 2 watercooled 780's.
Edits: Get a Kraken x60 instead of the h100i if possible--more quiet.
The 4670k would do the job just fine. If you are using the i7, you might end up disabling hyperthreading just so the actual cores run better for WoW.
No need for a Caviar Black if you already have an ssd. A seagate barracuda would be cheaper and does the job just fine. If you really are a speed freak, put 2 barracudas in raid 0.
Dominator ram is a waste of money. Ram is ram and brand does not affect performance. Any CL9 1600 ram will do.
