I am ordering a new case and the case fans/CPU cooler tomorrow. The case of choice is a NZXT S340. Will most likely be running a 4690k with a Hyper 212, GTX 970 (blower style fan). What would be the optimal cooling solution/airflow for me? 5$ per Arctic Cooling F12 120mm atm as well.
Is this the text below my post?
https://linustechtips.com/topic/502911-cooling-for-my-system/
Stock cooling is fine mate.
However, those F12 fans produce little to no airflow (i have them) so i'd invest in noctua's (not sure which model).
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/502911-cooling-for-my-system/#findComment-6714933
Aww really? Looking at the specs it didn't seem bad at all, and they were only a fourth of the price of a Noctua.. :<
https://linustechtips.com/topic/502911-cooling-for-my-system/#findComment-6714943
Yeah afraid so, they do the job for me but i didnt have any preinstalled fans.
So i would probably have a Dual 140mm set up in the front and a 140mm at the back or top.
But tbh i probably wouldnt bother, I'd put the money into something else and if i have temp problems then i would change up the fans.
But i wouldnt worry about it.
https://linustechtips.com/topic/502911-cooling-for-my-system/#findComment-6714988
Why do you think they were so cheap? If you don't want to invest much in Noctuas then get some Noiseblockers or be quiet! Pure Wings 2 or Silverstone Air Penetrators.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/502911-cooling-for-my-system/#findComment-6714991
Yeah but looking at the specs they seemed fine, and they were the best selling on the retailer website I was looking at. Would it be necessary with more than the stock ones? (2x120mm 1 front 1 back)
https://linustechtips.com/topic/502911-cooling-for-my-system/#findComment-6715018
Arctic F12's produce just as much airflow as any of the other mentioned fans--they're just not as quiet.
Fan specs aren't really reliable. Stick to benchmarks instead.
Arctic F12's are very middle-of-the-road and aren't bad. I'd suggest sticking with stock fans and seeing how they fare before looking at aftermarket options.
https://linustechtips.com/topic/502911-cooling-for-my-system/#findComment-6716804
Sound is not really much of an issue to me.
Yeah I suppose anything is better, currently running a mATX case with a single 120mm intake fan in front of the HDD bay, and it sucks bigtime.
https://linustechtips.com/topic/502911-cooling-for-my-system/#findComment-6718138
