Hey guys, in preparation for my upgrade to Alice, Project Alicization V2, I am in the process of cleaning parts. But I am unsure of how to go about cleaning the motherboard.
This motherboard was previously owned by a smoker, and although I have removed most of the dust that was choking the board (which I have tested to the best of my ability, it appears to work) I however would like to finish cleaning the motherboard to get rid of any dust that remains.
How can I go about doing this without compressed or canned air? The nearest store that sells canned air is about five miles away from where I live, and I do not own a car or have a way to get there (Winter is coming, and my bike was stolen)
My procrastination is the bane of my existence.
I make games and stuff in my spare time.
https://linustechtips.com/topic/502816-cleaning-some-old-hardware/
Even if you had compressed air cans, it wouldn't get rid the smell of smoke from the motherboard when it heats up.
You could dump a bunch of Isopropyl alcohol 99% on the motherboard and use a very, very soft toothbrush or something, to clean off the PCB though. Since that's not conductive. (Let it dry for a while after)
Or if you really just want to remove the dust... just use a toothbrush. (do not use in the contacts like the memory slots or PCI slots, etc... risk damaging those)
You could just dump a bunch of Isopropyl alcohol 99% on the motherboard and use a very, very soft toothbrush or something, to clean off the PCB though.
Or if you really just want to remove the dust... just a toothbrush. (do not use in the contacts like the memory slots or PCI slots, etc... risk damaging those)
Particularly the CPU socket...
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
All I could think about is this....
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
The cpu socket is spotless, actually. I'll probably use a cotton swab to clean it though if I really need to. (It's like the one clean component in the entire pc I pulled it out of, lol)
As for the cigarette smoke smell, i'm not worried, I live with a smoker anyway. I just need to put some filters on it so none of that stuff suffocates the rig's internal componants once it is built
