BEST thermal paste?
Go to solution Solved by TheGrim123321,
TheGrim123321
CPU: I3-4170Cooler: Hyper TX3Mobo:Biostar B85MGMemory: G.Skill Ripjaw 2x4GBStorage: Barracuda 500GBGPU: Zotac GTX660Case: Fractal 1100PSU: Evga 500WMonitors: FHX2153L 21.5"│V193WEJb 19"Keyboard/Mouse: CMStorm DevastorAudio: MonoPrice 8323Microphone: BlueYeti BlackoutOS: MSX(Win10) Quote me or @TheGrim123321 to get my attention.
https://linustechtips.com/topic/499972-best-thermal-paste/#findComment-6677374
I use MX-4, if you delid one use Coollaboratory Liquid Ultra on the die. If you get an AIO the stock paste on those are actually pretty good usually.
https://linustechtips.com/topic/499972-best-thermal-paste/#findComment-6677397
I used all kind of Paste over the Years. Never noticed any difference.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/499972-best-thermal-paste/#findComment-6677419
doesn't make too much difference honestly... i haven't personally used a huge variety of brands but someone who does computer maint for a living told me that it doesn't make more than ~3 deg of difference between any mainstream pastes
http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616-17.html
seems to check out
https://linustechtips.com/topic/499972-best-thermal-paste/#findComment-6677456
I'm surprised to not see the "toothpaste or other bodily fluids" joke  :rolleyes:
Anyways ya whatever thermal paste you have or want will work, the difference is negligible between types.
A shadowy flight into the dangerous world of a man who does not exist.
Core 4 Quad Not Extreme, only available on LGA 557 at your local Circuit City
https://linustechtips.com/topic/499972-best-thermal-paste/#findComment-6677617
For OCd liquid cooling.
That seems like a solid choice.
CPU: i7-6700K 4.7GHz GPU: GTX 980 STRIX 1337MHz CPU Cooler: H110i GTX AIO |
 Motherboard: Asus Z170-AR | Case: NZXT H440 White PSU: CS750W |
 PCPartPicker Link: http://au.pcpartpicker.com/p/43BkVn
https://linustechtips.com/topic/499972-best-thermal-paste/#findComment-6677739
