I have a rig that will not post the fans all spin up and then turn off about ten secs after I start it :(
The specs are
amd phenom x4 at like 1.9 GHz
3 gigs ddr2
550W psu
So what do you think this might be?If you need more info let me know :)
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/
strip it down including disconnecting all cable's, and reconnect 1 by 1 trying it to see if it posts each time.
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665733
What psu? Could that have issues delivering power?
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665751
550W asus A-55GA
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665759
550W asus A-55GA
Does it make any weird sounds or other signs of dying?
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665765
Nope all it will do is start the fan then go for 5-10 secs and then the fan will stop and it will not post
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665779
The power supply itself may be malfunctioning. Has this computer worked fine before? Or did you just get it?
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665783
It worked when it was in my rig
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665788
The motherboard may be shorting out then, if the PSU is in working order(assuming I understood your most recent post correctly).
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665792
Ok :(
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665798
Try removing the motherboard from your case and attempting to start it up(with the cooler still attached of course). If you don't know how to do that, I can tell you.
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665806
I have no idea how to do that...But I am taking it out right now :)
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665815
You'll need a flat head screwdriver. Find the power switch pinouts and touch the flat head screwdriver to both pins simultaneously. It'll cause the pins to short together causing the motherboard to tell the PSU to turn on and of course turn on the motherboard.
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665824
Or I can take the power button out of the case?
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665835
You can do that too if you wish.
https://linustechtips.com/topic/49950-i-need-some-help-with-a-pc/#findComment-665841
