Why is my core clockspeed so low in arma 3? i get the same fps with the r9 as i did with the hd 7870
everything is at stock settings, no overclocking,
im getting the data from msi afterburner
I have tried tweaking with startup parameters, settings in windows and ingame
Temperatures are rock solid at
GPU 50C
CPU 46C
Running Arma 3, ultra settings, multiplayer (same results with LOW, STANDARD and HIGH settings)
20-30fps
300-400mhz core clockspeed (gpu)
1500mhz memory clockspeed (gpu)
cpu 30-40% load
Valley Benchmark
40fps average
300-1000mhz core clockspeed (heavily fluctuating)
cpu 80-95% load
Resident evil 6 benchmark
50-60 fps avg
800-1000mhz core clockspeed
cpu 80% load
Assasins creed black flag
60 fps
500-900mhz core clockspeed
cpu 60-85% load
System:
Win 7
AMD apu a10 6800k 4.1-4.4
kingston hyperx 1866mhz ddr3 8gb (2x4gb)
crucial m100 512gb SSD
GA-F2A88XM-D3H motherboard
coolermaster v850 850W PSU
Sapphire Radeon R9 390 Nitro 8gb
hopefully someone can point me in the right direction, because i am lost as a cat in the middle of the atlantic.
https://linustechtips.com/topic/499205-r9-390-core-clockspeed-problems/
I feel like your CPU is bottlenecking your gpu but im probably wrong
I thought that but the load is only 40% apparently.
Which 390? Help us to help you.
It's the Sapphire Radeon R9 390 Nitro 8GB, he wrote it in the post.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
there is no way I dont think that isnt a huge bottleneck though
"God created war so that Americans would learn geography"
I made an edit.
40% CPU usage doesn't mean there isn't a bottle neck. But I wouldn't jump to that conclusion until everything else is looked into. Like trying different drivers.
If anyone asks you never saw me.
Arma III runs like crap on anything you throw at it, that's the problem.  But yes, a better CPU would certainly help.
An A10 APU with R9-390 is pretty unbalance. You need better CPU, probably i5 or Skylake i3.
Arma3 run like shit on 99% of hardware configuration.
