Need help with GTX 750
Izzat
DO NOT, I REPEAT DO NOT
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
I've recently ordered a GTX 750 online and it has unspecified brand/manufacturer.
Need help confirming if it's real so I could cancel the order if it's fake and before it's too late
url: http://www.lazada.com.my/geforce-nvidia-gtx750-2g-d5-128bit-gaming-graphic-card-super-power-4336850.html
i would say it's fake and probably a cheap chinese knockoff.
At best i would expect a gtx 460 , at worst an 8800gt or older.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
could be one of those fake cards
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
"GAMING GRAPHIC CARD SUPER POWER"
http://www.ebay.com/itm/Vamery-GTX760-2GB-128Bit-GDDR5-PCI-E-HDMI-DVI-Graphics-Video-Card-2-Fan-New-/351425291032?hash=item51d2946318:g:K3QAAOSwMmBVrZo3
Its the exact same card, yet a 760
not the same cooler or brand though , but probably also a knockoff
I think that spending just a little to get a 750ti will serve you way better than a 750.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Look at the cooler, its the same design with the 3 spikes at the end, just because the sticker is different doesn't mean anything.
Alright! I'm getting like 5 million replies saying it's fake under 10 minutes.
Might as well cancel the order and buy a card from some well known manufacturer.
Thanks guys.
i don't think it matters , really anyway considering what the card is
Thanks guys.
Try looking for a 750Ti since it is a bit pricer but way better.
Thanks guys.
Sorry man, i get ya it was cheap and looked good. Wish you luck in finding a good GPU
The thing about this GPU is that it was only 70 dollars, while the next cheapest 750 is 140 dollars
Not a 750 - 750s don't have VGA ports
After doing a little research turns out they are just re branded 8000 series cards :(
Yeah what a pain hahaha.
Need something to replace my dying old HD 6670
Thank god i decided to ask on this forum. Even had this account registered few minutes ago just to do so.
  :D
Oh wow didn't notice that!
