As the title say, I'm running into problem with MSI lightning 770, unable to plug it into the first pcie 3 slot because the heatsink I'm using is too big. GA z87x ud3h, Thermalright Silver Arrow Sb-e Extreme. So my question is can I plug it into the second pcie3 slot without any decrease in performance. My mobo has 3 pcie slot, and the specs is PCI Express 3.0 x16: 3 (x16/0 or x8/x8 or x8/x4/x4). Does it mean that I can plug my gpu into any of these 3 slots, and as long as I'm using 1 gpu, it will always run at x16 speed?
Thank you for helping me. Sorry for my bad English.
https://linustechtips.com/topic/49604-gpu-and-pcie-3-question-help-me-please/
I don't think it will run at 16x, but there really isn't too much of a performance decrease to notice.
even if the second 16x slot is only wired 8x it runs at 99% of the performance of a full 16x wired slot
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
You can plug it into any of the pci-e slots and get the maximum bandwidth, aka speed
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
