Screw trouble... Please help!
By
datgoogoo
in Troubleshooting
in Troubleshooting
Solved by Tedster,
Please don't use washers on your mobo screws. The mobo insulates itself just fine if you're doing things properly.
As for which screws to use, judging by what I used the first ones.
Really if they work with the threading of the standoffs and they don't protrude past the ring on the mobo around the screwhole and they get you to the right height they're all fine.
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18
play_circle_filled
Latest From ShortCircuit:
