http://www.extremetech.com/extreme/164698-wax-cooling-can-massively-speed-up-processors-for-short-bursts
Researchers at the University of Michigan have turned to wax to help push microprocessors to the limit. The wax can efficiently absorb heat as it changes phase and begins to melt.
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/49508-wax-cooling/
https://linustechtips.com/topic/49508-wax-cooling/#findComment-659588
Up to 50 watts is not an ultrabook CPU
sry misread I saw 10w and thought they made it run at 50w.
https://linustechtips.com/topic/49508-wax-cooling/#findComment-659596
Id rather put whole system into oil.
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
https://linustechtips.com/topic/49508-wax-cooling/#findComment-659641
Just add a wick and instant light!
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/49508-wax-cooling/#findComment-659739
I really don't think that would work...
It sort of would, just like any other material, wax will absorb heat energy to change in state (solid-> liquid) without actually changing in temperature before it has completely finished melting.
So it would work... for the seconds it takes for the wax to melt, then it's pretty much useless. and it's not like it performs so extremely well that extreme overclockers might want to use it (the type of wax used here melts at 54C) so I really don't see the point in this for PCs...
This makes more sense on smartphone/tablet chips, which usually run without any sort of active cooling, some smartphones already frequently throttle due to temps so this could be used to give the chip a little bit more cooling while running at 100% and then the wax becomes solid again after the user stops using performance heavy tasks/puts it to sleep.
https://linustechtips.com/topic/49508-wax-cooling/#findComment-661074
If they are using phase change of the wax, couldnt they use a different material that melts at a higher temperature, so that it can absorb more heat?
Yes they actually said so in the article, that doesn't necessarily mean the material will absorb more heat, just that it will do so at a higher temperature. The melting temperature should be somewhere in between the normal operating temperature of the chip and the "boost" operating temperature so that it would allow the material to melt and cool repeatedly.
https://linustechtips.com/topic/49508-wax-cooling/#findComment-662877
Wonder what kind of overclock you can achieve with this. But this wouldn't last long so it won't be a good solution for long term cooling since you can only cool it with short bursts.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/49508-wax-cooling/#findComment-666291
I think this would have some potential in phones and tablets, maybe ultrabooks. Anything big enough to fit in a real heatsink and fan probably should go with that in order to have more consistent cooling.
But take the HTC One for example. If I start doing anything significant it gets warm almost immediately due to the metal construction allowing the heat to move from the internals into the back. If one of these wax things (or, if it gets popular, probably some kind of custom material they science up) were installed, it could go longer without becoming uncomfortable to hold, or go full-power for a while to get something done quickly without getting hot at all. I mean, I don't consider it a great replacement for real cooling options, but it seems to be small enough that it could be used in things that don't really have any other options.
https://linustechtips.com/topic/49508-wax-cooling/#findComment-667737
