CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($108.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($89.99 @ Newegg)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($269.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($54.40 @ SuperBiiz)
Total: $1003.80
Generated by PCPartPicker 2015-11-27 19:55 EST-0500
https://linustechtips.com/topic/494155-first-build/#findComment-6616143
Total: $1003.80
Why is the OS $20? I plan to download via USB drive
https://linustechtips.com/topic/494155-first-build/#findComment-6616164
It's a very well rounded build but I'd recommend getting a 240gb ssd, the 128gb is fine (what I have currently) but that extra space on it to load your favourite handful of games would be really nice to have
If you have the option to get a high refresh rate monitor, do it.
Main PC CPU: i7 14700k CPU Cooler: NZXT x62 280mm Motherboard: Gigabyte Aorus Elite X WiFi 7 GPU: Asus Strix 3080ti RAM: Gskill Trident Z5 32gb DDR5 SSD: 990 Pro 2TB, 980 Pro 1TB Case: NZXT S340 Black PSU: Corsair RM1000e ATX3.0
Server: CPU: i7 9700k RAM: Corsair 32gb DDR4 HDD: 36tb Usable SSD: Samsung 500gb NVME Case: Fractal Define R5 PSU: Corsair RM1000e ATX3.0
https://linustechtips.com/topic/494155-first-build/#findComment-6616211
I was thinking of adding a 240gb SSD in 2-3 months
https://linustechtips.com/topic/494155-first-build/#findComment-6616218
That's almost the same build as mine, the main differences being: I have a different case, a 650 watt PSU, a 240GB SSD instead of 120, and a 960 instead of a 380x.  So by all means, this seems like a great build.   :)
I would recommend a r9 380 4gb(for around the same price) unless you really want Nvidia software.
http://pcpartpicker.com/part/sapphire-video-card-100384nt4goc2l
https://linustechtips.com/topic/494155-first-build/#findComment-6616270
I kind of had to have a NVIDIA Card, because I use blender to do 3D rendering.  And Blender uses CUDA Cores, rendering with stream cores in AMD Cards isn't supported.
https://linustechtips.com/topic/494155-first-build/#findComment-6616314
